tig.mokie1.com
FIXED- Subscribe to RSS Feed
- Everything else
- tig.mokie1.com
- « Previous
- 1
- 2
- Next »
Re: tig.mokie1.com
17-03-2017 12:28 PM
@Anonymous 'Yes' as I should be worried? It sets a cookie, but doesn't seem to do much else.
17-03-2017 12:30 PM
Oops!, I mean @jab1 you shouldn't worry about it, sorry for the confusion.
Re: tig.mokie1.com
17-03-2017 12:33 PM
@Anonymous -OK, I'll ignore it, and just continue 'stop loading this page', the few times I visit the Members Centre.
Re: tig.mokie1.com
17-03-2017 12:34 PM - edited 17-03-2017 12:37 PM
I can't get the portal home page to fully load and I get 'Transferring data from www.plus.net...' having logged in.
I do see 'tig.mokie1.com' briefly in the bottom left during the login page load.
The portal home page never fully loads but as it's a stepping stone to further pages it's not a problem.
Re: tig.mokie1.com
17-03-2017 1:03 PM
I don't know if this is going to help or hinder but these are the non Plusnet URLs scraped from the page after I login.
https://www.dwin1.com/2973.js HTTP/1.1 200 OK 21ms] https://www.googletagmanager.com/gtm.js 8ms] https://www.googletagmanager.com/gtm.js 7ms] https://webstats.plus.net/dcskzw9b87mbvp4ejoyvlnmt0_8o1k/dcs.gif HTTP/2.0 302 Found 31ms] https://analytics.freespee.com/js/external/fs.js 5ms] https://track.uniqodo.com/13.js HTTP/1.1 200 OK 42ms] https://logs128.xiti.com/hit.xiti HTTP/1.1 302 Moved Temporarily 106ms] https://webstats.plus.net/1pixel.gif HTTP/2.0 200 OK 31ms] https://logs128.xiti.com/hit.xiti HTTP/1.1 200 OK 103ms]
Probably just serve to confuse but may be useful.
Re: tig.mokie1.com
17-03-2017 11:07 PM
No, that's called Nightly, as it's a nightly build in 64bit.
Hope this helps.
Re: tig.mokie1.com
18-03-2017 7:26 AM
@Rsebrie - ? Was this meant for this thread?
Re: tig.mokie1.com
18-03-2017 7:43 AM
@jab1 - I think this is a reference to your WaterFox browser.
Re: tig.mokie1.com
18-03-2017 11:53 AM
Morning
Yes. I saw you said it was called Waterfox (sorry I've never heard of that) And as I've worked on Nightly for several years now, I thought I'd see if that's what you meant.
The 64bit version of Firefox is Nightly.. Its my browser of choice now we don't have Netscape anymore.
Just trying to help.
Hope all is well and your problem gets sorted asap.
Kind regards
Richard
Re: tig.mokie1.com
18-03-2017 12:51 PM
@Rsebrie - No problem, Richard. I also have FF, but only the 32bit version. WF has been around for a while, before FF64, and I've stuck with it.
Problem solved btw - the offending site just can't get past ad-muncher.
Re: tig.mokie1.com
18-03-2017 1:10 PM
Good news then. 👍
What Ad Muncher are you using? I use Ad-Blocker plus in Nightly, IE and Edge, I used GreaseMonkey and Ghostery in Windows 7, but Windows 10 is completely different.⚠️💻⚠️
Im glad someone told you to use the debug console, as that's the way I'd go about it.📺
Ive only just figured out that Java isn't supported in a Firefox, Nightly or any other variant, but am too chicken to remove the Java installed on my PC for "other browsers." That and that I have 32bit and 64bit Java installed. I should only really have one installed, the 64bit version as I'm running Windows 10 Pro 64bit, but yet again, too chicken to do anything about it.🤕
At the moment, I'm just keeping my PC functioning, as I've been getting Display Driver Errors, USB hub errors, and lots of run time errors. I don't mind this, as long as it lasts until the creator update comes, then as long as I can download that and burn it off I can start again with a clean factory reinstallation.💻👍
Well I say that, but I have to learn an new technique for installation again this time. Not only do I have to install pre install drivers, before I install Windows, I've now found out I have to update my Harddrives Firmware via a UEFI boot up disk first, then do my preinstall drivers, then install Windows, then install Drivers and then apps.🤔
So I probably won't be online for a week or two whilst doing this. I know it's gonna be tuff to pull off, but I know it's going to be worth it in the long run.😏
Anyway, sorry, going off track. I'm glad you've figured out it's a redirect to nothing, but I'd still block that cookie. I'm miss the days of HTML, before DMHTML and HTML5. I've still got my old copy of Dreamweaver, but never use it anymore, as I have no idea what I'm looking at in the code nowadays as soon as I see the dreaded Java Snipet...💥
Anyways, best to be safe than sorry.🤓
Glad you got some help here
Kind regards
Richard
Re: tig.mokie1.com
18-03-2017 1:31 PM
@Rsebrie - You could start a thread of your own if you want specific help but you really shouldn’t worry about uninstalling the Java Runtime (JRE), to be fair to Java that was one of the good things about it in that if you do have an application installed that relies on the JRE when you run the App it will bleat, at which point you can re-install the Runtime it needs.
Be bold, take the steps and free up some hard disk space.
Re: tig.mokie1.com
18-03-2017 2:16 PM
@Rsebrie The program I referred to is exactly that - if you Google it, it should be the first result if you use 'ad muncher' as your search term.
It is cross-browser, and IMHO lighter and much more customisable that many other tools. It is the only one I use now, and has been for the past 4 or 5 years.
Re: tig.mokie1.com
19-03-2017 8:02 AM
Just a final comment - As of yesterday, I think I still see this on loading the Members Centre, but it does not 'stick'
- « Previous
- 1
- 2
- Next »
