smf database move
- Everything else
- smf database move
smf database move
02-03-2015 4:59 PM
Hi
I've moved from my old hosting site to a new one. I had a small smf up and running and always did regular backups using the smf the> 'forum maintenance' > 'back up data base download'.
I installed a new smf using cPanel on my new hosting site and tried to upload my old mySQL backup file that I had on my hard drive. Unfortunately it kept coming up with errors.
Any idea where I have been going wrong or even is it possible to move one smf database from a site to another?
Message 1 of 4
(1,335 Views)
3 REPLIES 3
Re: smf database move
02-03-2015 5:34 PM
Quote from: firkin Any idea where I have been going wrong or even is it possible to move one smf database from a site to another?
Yes, it should be possible, assuming both sites are using similar versions of MySQL.
Quote from: firkin Unfortunately it kept coming up with errors.
What sort of errors? They may offer a clue as to what's happening.
Message 2 of 4
(259 Views)
02-03-2015 9:57 PM
Hi Bob
Thanks for your reply, when I looked closley at the error message it did give me a clue. I'd not changed the dir to the new one called 'archive'. I would never had thought to check that but for your help, so many thanks Bob.
Message 3 of 4
(259 Views)
03-03-2015 12:33 PM
No worries, glad to hear you cracked it
Message 4 of 4
(259 Views)
