sending files to webspace via ftp
- Everything else
- sending files to webspace via ftp
16-09-2008 10:25 PM
Sorry if this is a really simple question,
Is it possible to send files via ftp to my plusnet webspace from outside the plusnet network, for example if im at work connected thru btinternet?
Thanks for the help
Thanks for the help
Message 1 of 3
(1,098 Views)
2 REPLIES 2
Re: sending files to webspace via ftp
16-09-2008 10:45 PM
Yes, this is indeed possible on any of our subscription accounts.
If using our mail only or non-subscription dialup (0845) account, this is not possible and you would need to connect via our network.
So if you have Broadband with us, this will work for you.
Message 2 of 3
(237 Views)
16-09-2008 10:46 PM
Excellent!
Thanks for the rapid reply
Message 3 of 3
(237 Views)
- Everything else
