rewrite rules in .htaccess file help needed
- Everything else
- rewrite rules in .htaccess file help needed
02-07-2011 5:48 PM
I have an application build on Zend framework with a typical Zend Framework .htaccess files. I installed the app on many servers, but I completely cannot install it on your server. Obviously the problem must be with .htaccess rules. Could someone have a look and modify them? This can be helpful for others trying to install Zend apps. Thanks
RewriteEngine On
###### rewrite base
RewriteBase /cpbc/public/.
###### rewrite conditions
RewriteCond %{REQUEST_FILENAME} -s [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
###### rewrite rule
RewriteRule ^.*$ index.php [NC,L]
Message 1 of 2
(837 Views)
1 REPLY 1
Re: rewrite rules in .htaccess file help needed
03-07-2011 11:54 AM
Assuming that .htaccess file is in the /cpbc/public folder try setting the RewriteBase line to
The file needs to be uploaded as ASCII with access permissions set to 0640.
Have you set file and folder permissions as described in the CGI platform upgrade FAQ?
David
Message 2 of 2
(155 Views)
- Everything else
