reverse DNS
fatherjack666
reverse DNS
Hi
How can I get a reverse DNS as mine is set to fatherjack666.plus.com, but it should be box.fjg.org.uk any help would be much appreciated
14 REPLIES 14
Fixes: 479
Re: reverse DNS
Moderator’s Note
This topic has been moved from Broadband to Everything Else
C1Rider
Re: reverse DNS
Hello,
Do you have a registration for DNS that needs to be configured ?
host fatherjack666.plus.com
fatherjack666.plus.com has address 80.229.5.193
host box.fjg.org.ukhost 80.229.5.193
193.5.229.80.in-addr.arpa domain name pointer fatherjack666.plus.com.
host box.fjg.org.uk
box.fjg.org.uk has address 80.229.5.193
box.fjg.org.uk mail is handled by 10 box.fjg.org.uk.
Regards..
fatherjack666
Re: reverse DNS
Dont understand what you mean, the mail in a box server I have setup has this error@
Your box's reverse DNS is currently fatherjack666.plus.com, but it should be box.fjg.org.uk. Your ISP or cloud provider will have instructions on setting up reverse DNS for your box
Thats why I contacted youeselves
C1Rider
Re: reverse DNS
Hello,
I didn't realise that you were setting up a mail server, I thought your question was about DNS only.
This link may help:-
<  https://mailinabox.email/  >
Regards..
fatherjack666
Re: reverse DNS
Thx, I have gone through all that just this error I get refers to the reverse DNS needs to be set by your ISP
Fixes: 479
Re: reverse DNS
@fatherjack666
If you wait until a Plusnet agent comes along they will arrange to change this for you.
fatherjack666
Re: reverse DNS
excellent that would be great
willcutforth
Fixes: 113
Re: reverse DNS
Hey there @fatherjack666 if you reply to the ticket here I will get this actioned for you
 Will Cutforth
fatherjack666
Re: reverse DNS
Sent a reply thank you
willcutforth
Fixes: 113
Re: reverse DNS
All raised up now and it should be done within 72 hours. Smiley
 Will Cutforth
fatherjack666
Re: reverse DNS
excellent thank you very much for the speed in sorting this now for the battle with Spamhaus they wont remove me from the blocklist
willcutforth
Fixes: 113
Re: reverse DNS
The daily struggle. Hope you get it sorted Smiley
 Will Cutforth
fatherjack666
Re: reverse DNS
I hope so as well, they are saying because this is a new domain with no reputation it will stay on the block list for a while but I will keep plugging away at them
fatherjack666
Re: reverse DNS
Hi
Just checked Mail in a Box system check and its still say
Your box's reverse DNS is currently fatherjack666.plus.com, but it should be box.fjg.org.uk. Your ISP or cloud provider will have instructions on setting up reverse DNS for your box.
