plusnet protect
- Everything else
- Re: plusnet protect
plusnet protect
09-04-2019 9:34 AM
I'm confused by the following paragraph on your website:
It depends which broadband package you've got. It's free for Unlimited and Unlimited Fibre Extra customers. And it's £2 a month if you've got Unlimited Fibre.
It states it's free for unlimited fibre, but then goes on to say it's £2 for unlimited fibre. I have unlimited fibre so not sure if it's free or it's £2.
Re: plusnet protect
09-04-2019 11:43 AM - edited 09-04-2019 11:44 AM
If you read it again you will see that it says free for unlimited fibre extra. You are on the slower package. Personally I would not touch this Mcaffee product. Get your own Internet Security suite and install it on your devices. Norton or Kaspersky are recommended.
Re: plusnet protect
09-04-2019 11:49 AM
Hi @steedie1, thanks for getting in touch.
I do apologise for the confusion there has been. If you're on the standard Unlimited Fibre package then there is a monthly cost of £2 to use Plusnet Protect. If you'd like to add the feature you can do so via here: https://www.plus.net/home-broadband/protect/
Let us know if you need anything else
Re: plusnet protect
09-04-2019 11:53 AM
Moderators Note
This topic has been moved from Fibre to Everything Else.
Re: plusnet protect
09-04-2019 2:35 PM
Thank you for your replies.
Just to say that I did read it and the way I read it was " Unlimited and Unlimited Fibre Extra, so I took that as "unlimited " and "unlimited fibre extra " two seperate items. hence my query..
Re: plusnet protect
09-04-2019 2:36 PM
also, no-one seems to have a good word to say about Mcafee, so will stick to what I have..
