phpyMyAdmin slow
- Everything else
- phpyMyAdmin slow
phpyMyAdmin slow
03-12-2010 10:32 AM
Re: phpyMyAdmin slow
13-02-2011 11:15 AM
13-02-2011 12:58 PM
With every server I've used it on it has always randomly slowed down for unknown reasons before randomly speeding up again. Sadly there isn't really any alternative to phpmyadmin
13-02-2011 7:23 PM
13-02-2011 8:35 PM
14-02-2011 6:45 AM
14-02-2011 11:03 AM
Quote from: okrzynska I'm not a fan of it anyway to be honest.
MySQL Administrator and MySQL Query Browser (you have to get them from the archives - not the current MySQL Workbench) work well.
Edit: To access the MySQL servers directly from you local PC you use rumpus.plus.net and humbug.plus.net as the server names
Edit2: http://downloads.mysql.com/archives.php?p=MySQLAdministrationSuite&v=1.1.20
15-02-2011 1:57 PM
Edit: the database responsible for authentication is pretty old and needs upgrading, but there shouldn't really have been an increase in take up for the service as we no longer offer it on new accounts. Keep on eye on things and if the situation worsens/doesn't get better then I'll raise a problem on it. If people know roughly when this started becoming an issue then that might help pinpoint what caused it?
15-02-2011 10:25 PM
The problem has been going on since I started this thread.
Here's a Firebug Net Trace for me logging in:
http://www.pemmaquid.plus.com/phpmyadmin.png
Once I've logged in it takes about 8 seconds to select a table
17-02-2011 6:48 AM
17-02-2011 9:32 AM
Selecting a table 6.7 seconds.
I'm on humbug, which are you on Steve?
17-02-2011 12:36 PM
login 18.9 seconds
select table with 11,000 rows 7.6 seconds
second table with just 4 rows 41.6 seconds, most of which seemed to be waiting for server response, then 5 seconds to complete
third table with 12,250 rows 6.8 seconds.
17-02-2011 3:46 PM
Peter Beaven
17-02-2011 5:44 PM
Quote from: spraxyt Using humbug
Those look very similar to my timings - and I'm on Humbug... .so that's three of us on there with lousy timings....
17-02-2011 11:20 PM
rumpus login 10.0 and 10.6 seconds (repeated after checking humbug)
select table with 24450 rows 4.5 seconds - didn't repeat select tables
select another table with 284 rows 3.7 seconds
select third table with 27480 rows 3.9 seconds
humbug login 17.5 and 17.1 seconds (after repeat check on rumpus)
select table with 23500 rows 27.8 seconds but (different table) 6.3 seconds on second login
select another table with 2 rows 33.5 seconds but (different table) 5.9 seconds on second login
select third table with 27500 rows 39.3 seconds but (different table) 6.3 seconds on second login
So it looks as though humbug is generally slower, but speed can vary a lot within a short time.
David
