phpgedview help
- Everything else
- phpgedview help
phpgedview help
08-05-2010 6:31 PM
One issue seems to be PGV's request for 777 file/folder permissions versus what Gabe's posts suggest and what suExec will allow. Is there a solution?
Cheers,
Adrian
Re: phpgedview help
09-05-2010 2:33 PM
Yep there have been a few issues regarding PGV, However, i have been succesfull in running 4.2.3 full install on PN and also within a Joomla! wrapper.
FTP the zipfile to your webspace on the CGI server set the permission to "execute" and unzip it..
Set the neccesary file permissions to 750 or 751, anything more and the server will not like you! ~Dont forget to set your configuration file permissions back to read only after you have done.
If yo have problem with PGV creating the database, make sure your MySQL is activated and you have provided PGV with the correct path and username etc etc. If it still fails and it returns a SQLSTATE 42000 syntax error then ask PN to check your permissions for MySQL. My own were initially incorrect so it threw this error. This was quickly resolved by PN.
There is plenty of help available and experience here on the forum, so just ask if you have a problem,mine was certainly sorted out.
Regards, James
Re: phpgedview help
10-05-2010 5:08 PM
Yes, after a few initial problems (possibly due to PN doing some post-release fine tuning) I have 4.2.3 running OK. I have .php files set at 700 and everything else as 640. I set config.php to 500 once I was happy. I used Gabe's phpwrapper script to tidy up the PGV login URLs. I had some issues with SEF in Joomla which I have not had time to resolve yet - but everything works.
Good luck,
Stuart
Re: phpgedview help
10-05-2010 7:54 PM
Thanks guys. I've made some progress but can't connect to the database, error message 'Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)]'
Does database host have to be anything more than just 'rumpus'? Port I've left blank, and username, password and database name are all as per the mySQL activation email. The only other boxes on PGV installation are:
Use persistent database connections: No
Use the database to provide UTF-8 collation: No
Database Table Prefix: pgv_
Are these OK? What am I doing wrong?
Cheers,
Adrian
Re: phpgedview help
12-05-2010 7:03 PM
My database config to create the tables was as such
Database Type MySQL
Database Host RUMPUS (or what was in your activation email)
Database Port 3306
Database Username Your username usually the bit before .plus.com
Database Password The password in the activation email, not the login password for P N
Database Name usually username_pn (or what was in the email)
Use the database to provide UTF-8 collation Yes
Database Table Prefix pgv_ or whatever you prefer
Although PGV should use a default, try specifying the port address 3306.
Hope it helps,
Cheers, James
Re: phpgedview help
15-05-2010 10:37 PM
Settings as you suggested, but I get the following message:
Your current database configuration is bad. Please check your database connection parameters and configure again.
DB Error: connect failed [nativecode=Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)] ** Array
I contacted plusnet support with this message, but they just said that others have managed to host phpgedview, they couldn't help, and that I should ask for help here.
Any other suggestions?
Re: phpgedview help
15-05-2010 11:17 PM
Re: phpgedview help
16-05-2010 11:59 AM
Thanks for the help so far.
Re: phpgedview help
16-05-2010 12:16 PM
Using phpMyAdmin I deleted the tables that had been created then re-ran the phpgedview configuration file. When creating the tables it gives loads of error messages like this one:
ERROR:-26 DB Error: insufficient permissions
SQL:CREATE INDEX pgv_messages_to ON pgv_messages (m_to) [nativecode=1142 ** INDEX command denied to user 'username'@'212.159.7.205' for table 'pgv_messages']
Despite all these it still says Database Tables created successfully.
"Insufficient Permissions" - can I rectify this?
Re: phpgedview help
16-05-2010 10:13 PM
Hopefully they'll see this thread and respond as needed.
David
Re: phpgedview help
17-05-2010 10:41 AM
Quote from: Adrian00 Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock'
This makes me believe that the configuration isn't looking for a remote MySQL server.
It should be using TCP port 3306 to connect to the mysql server at rumpus.plus.net (or humbug.plus.net if that's your server). It appears to be using a local socket connection to connect to (what it believes is) a MySQL server running on the CGI server - but there isn't one!
Double check all the config settings in your application.
B.
Re: phpgedview help
17-05-2010 1:16 PM
I've passed your existing ticket back through to our networks team who will investigate these issues for you.
Re: phpgedview help
17-05-2010 7:21 PM
Quote from: Barry
B.
Thanks guys. I also tried specifying port 3306, but it gives the same message. Hope the networks team come up with something other than me doing something wrong...
Re: phpgedview help
18-05-2010 12:45 PM
Despite a few hiccups I managed to get phpgedview v4.2.3 installed and running a couple of weeks ago. However I still have an outstanding issue, more of which later. Hopefully some of the points below might be of help to you.
Points to note during the install were.
Having read a couple of other threads on the subject I set the folder/file permissions as follows
config.php 750
folders 710
script files 700
static files 640
When running the install script I initially got lots of messages of the type
ERROR 2: session_start() [function.session-start]: open(/tmp/sess_1062acd65c7523bd1c27eb3560484f9a, O_RDWR) failed:
File too large (27)
0 Error occurred on in function session_start
1 called from line 333 of file session.php in function require_once
2 called from line 75 of file config.php in function require_once
3 called from line 42 of file install.php
Warning: session_start() [function.session-start]: open(/tmp/sess_1062acd65c7523bd1c27eb3560484f9a, O_RDWR) failed:
File too large (27) in /share/storage/01/da/username/pgv/includes/session.php on line 333
These appeared before & after the phpgedview Installation Wizard window.
I tracked this down to pgv attempting to write its session data to some temporary storage to which it didn't have permission.
The solution was to create a new folder to hold the session data and point the SESSION SAVE PATH variable in the config file to it e.g.
$PGV_SESSION_SAVE_PATH = "./sessiondata/";
When running the install script subsequently I found that I had to reenter the database connection details each time as these were not being stored in the config file. I don't know whether this was because install script had not fully completed earlier or whether there was still a problem writing to the config file which at the time had permissions set to 750. In the end I manually editted the config file to include the database details. SQLhost name, DB name, username, password, etc., were set as per the email from dbcreator, I left the DBPORT variable to default. I also set the configured variable to true.
$DBPORT = "";
$CONFIGURED=true;
Basic point I know, but have you checked that your database connection settings are actually being stored in your config.php file?.
Subsequent runs of the install script gave me repeated "SQLSTATE[42000]: Syntax error or access violation: 1142 INDEX command denied..." error messages on Step 3 - Create Tables. MySQL admin showed that only three tables had been created. I DROPed these and reran the script a few times but each time only the first three tables were created. In the end I stopped DROPing the tables that had been created and kept running the install script until it completed step 3 and went on to finish at step 8. In all 20 tables were eventually created.
I reset the permissions on the config.php file to 500.
The application is running but response can be a bit lumpy at times. Not surprising since MySQLadmin shows that none of the table INDEXs were created.
There's obviously a problem with my CREATE INDEX permissions so I've raised a ticket, no 33385164. Once I get a resolution I'll try using MySQLadmin to create the indexes using DDL extracted from the includes/db_schema folder. I don't fancy doing a reinstall as I've already uploaded and configured a couple of GEDCOMS.
Hope this is of use.
Ian
Re: phpgedview help
19-05-2010 9:27 AM
Gabe
