phpMyAdmin not displaying properly
- Everything else
- phpMyAdmin not displaying properly
16-02-2016 12:57 PM
Hi
Is anyone aware of display issued with PHP my admin? I've tried all different browsers and logging in from different machines but still get the following layout (attached).. its almost impossible to use at the moment..
Message 1 of 2
(1,042 Views)
1 REPLY 1
Re: phpMyAdmin not displaying properly
14-03-2016 2:12 PM
Not aware of any issues and seems to be displaying OK here. Are you accessing it via a direct link or from the control panel? If from the control panel, then make sure you have the relevant domain selected in the management drop-down before opening the app. Failing that, you can try an uninstall/reinstall or use an alternative solution like Adminer.
Message 2 of 2
(611 Views)
- Everything else
