phpMyAdmin - how to change the value in a field for a group of records?
- Everything else
- phpMyAdmin - how to change the value in a field fo...
17-01-2009 9:56 AM
It's a phpBB database and I want to change the value of the poster_id field, after a search to find the ones I need to change.
The Search shows me this SQL...
SELECT *
FROM `phpbb_posts`
WHERE `post_username` = CONVERT( _utf8 'Freddie'
USING latin1 )
COLLATE latin1_swedish_ci
LIMIT 0 , 30
That brings up the first 30 of Freddie's records.
I want to change the poster_id field from -1 to 18, in all of his records (about 15000 of them). How do I do it?
SELECT *
FROM `phpbb_posts`
USING latin1 )
LIMIT 0 , 30
Message 1 of 2
(809 Views)
1 REPLY 1
Re: phpMyAdmin - how to change the value in a field for a group of records?
17-01-2009 1:16 PM
I've sorted this out now.
I couldn't see how to do it in phpMyAdmin, so I did it from the command line in the end.
Message 2 of 2
(219 Views)
- Everything else
