phpMyAdmin access denied
FIXEDTopic Options
- Everything else
- phpMyAdmin access denied
30-11-2020 1:49 PM
When trying to access mySql database via My SQL Manager at hosting.plus.net/portal, I'm getting
mysqli_real_connect(): (HY000/1045): Access denied for user 'ccgiXXXXXXXXXX'@'91.136.11.86' (using password: YES)
The username is correct and the database is actually running ok; it's just phpMyAdmin that has the problem.
Any ideas?
Fixed! Go to the fix.
1 REPLY 1
30-11-2020 1:58 PM
Oh - the password in /private/phpmyadmin/config.inc.php was wrong.
Now working fine
- Everything else
