php & MySQL connection...
- Everything else
- php & MySQL connection...
22-04-2010 4:58 PM
Hi All, me again, the noob
I'm trying to connect to my MySQL database and use a simple select statment but am getting the following error returned:
Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
My php file looks like this :
<?php
$con = mysql_connect("localhost","username","password");
if (!$con)
die('Could not connect: ' . mysql_error());
mysql_select_db("username_pn", $con);
$result = mysql_query("SELECT * FROM subscriber");
while($row = mysql_fetch_array($result))
echo $row['FirstName'] . " " . $row['LastName'];
echo "<br />";
mysql_close($con);
I think its the 'localhost' parameters.
Can anybody shed any light on this?
Many thanks.
<?php
if (!$con)
echo "<br />";
mysql_close($con);
Many thanks.
Message 1 of 2
(725 Views)
1 REPLY 1
Re: php & MySQL connection...
22-04-2010 6:20 PM
When you activated MySQL you should have received an email giving the server name (rumpus or humbug), username and password.
Message 2 of 2
(97 Views)
- Everything else
