pdf redirect
- Everything else
- Re: pdf redirect
pdf redirect
08-09-2008 2:33 PM
I have a link going direct to pdf documents on one site eg www.one.com/blah.pdf. The pdf's are moving to a new web site www.two.com/blah.pdf.
These pdfs are coming up very high in Google. I was hoping if I changed them to redirects Google would follow. Also for those that have a link in their web site to these pdfs it will be broken when I move them to the new url.
I have been advised to use the htaccess method. Will this work on plusnet?
Message 1 of 5
(1,639 Views)
4 REPLIES 4
Re: pdf redirect
08-09-2008 6:30 PM
htaccess redirects definitely do work, but be aware that there are some quirks to Plusnet's platform that can break some of the common htaccess examples given on the web, so test everything that you can!
Message 2 of 5
(616 Views)
Re: pdf redirect
08-09-2008 10:11 PM
wilco thanks oliverb
Message 3 of 5
(616 Views)
Re: pdf redirect
09-09-2008 4:33 PM
FYI This method worked a treat.
http://www.javascriptkit.com/howto/htaccess7.shtml
Thanks for the help
Thanks for the help
Message 4 of 5
(616 Views)
Re: pdf redirect
10-09-2008 12:22 PM
I forgot you could use "Redirect".
That's part of mod_alias I think and a lot easier than using mod_rewrite which I was thinking of.
Message 5 of 5
(616 Views)
