no-one can access my website that is on a domain hosted on plusnet. It worked unti 14 Oct 2025
dave
Fixes: 14
Re: no-one can access my website that is on a domain hosted on plusnet. It worked unti 14 Oct 2025
Do you know when the sites last worked? There was a change around 14th October as per the title of the thread, have they worked since then do you know?
Dave Tomlinson
Plusnet Technology
thejudge
In my own case, it worked fine up until sometime yesterday afternoon/evening (18/11).
This looks like a repeat of the problem from about 4 weeks ago: https://community.plus.net/t5/Everything-else/Can-t-access-https-homepages-plus-net/m-p/2025909#M397...
dave
Fixes: 14
Thanks, I can't see any obvious different from the sites reported here and one of our test sites that is working so looks like it may be different cause to last month so I've got it reported and will post back when I hear what the problem is.
Dave Tomlinson
Plusnet Technology
Lordwotsit
@dave Changes to the site were last made on 04/11 and it was visible then.
This morning I remembered that our site is actually osbornedance.plus.com but when we joined Plusnet in 2005 we took the offer of having osbornedance.co.uk domain name. Putting osbornedance.plus.com in my browser works fine whereas the .co.uk comes up with not found. This is where my DNS redirects etc knowledge starts to get thin but IMHO there is a pointer from plus.com to our .co.uk missing!
Hope I've explained this okay and that this is the issue. Also really hope that it can be resolved quite quickly 🙏
I've also added this to the Plusnet open question number 251523221
Cliff(Wotsit of Warwick)
“You will do foolish things, but do them with enthusiasm.” - Colette
steed
Just to add my website www.myusername.plus.com is working, it is just the .co.uk domain that is not.
So as above, likely something to do with the pointing of the domain name to the actual .plus.com webspace.
mystreet1
Fixes: 6
http://osbornedance.co.uk/
Is accessible @Lordwotsit
It appears to be an issue with your SSL which a lot of browsers now reject. Although you are probably not collecting any information from your site, browsers do not like the http route.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 237
@dave
It looks related to the subtle difference between
For the majority of folks they are interchangeable.
For those of us having fixed IP addresses in the context of account.plus.com, it makes the difference of pointing at home pages or our own home service.
dave
Fixes: 14
Thanks, found the cause, going fix it with a DNS change as that's the quicker resolution which should be out this afternoon. I'll confirm when it's done.
Dave Tomlinson
Plusnet Technology
dave
Fixes: 14
Should be fixed now, the 3 sites I've seen here are all working for me now.
Dave Tomlinson
Plusnet Technology
Fixes: 237
Appears to be all working for osbornedance.co.uk
Was this a point fix or a generic fix for all domains?
A root domain appears to point directly at Plusnet's servers, where as the www. version is routed via Greenbysites - should they not be the same?
> osbornedance.co.uk
Server:  [192.168.1.254]
Address:  192.168.1.254
Non-authoritative answer:
Addresses:  212.159.9.91
          212.159.8.91
> www.osbornedance.co.uk
Address:  212.159.8.91
Aliases:  www.osbornedance.co.uk
          homepages.plus.net
Also for reliance, should not the www. version also resolve to both IP addresses?
EDIT: Posts crossing with @dave
Champnet
Fixes: 18
@Townman Wrote :
"A root domain appears to point directly at Plusnet's servers, where as the www. version is routed via Greenbysites - should they not be the same?"    Not necessarily......
Fixes: 237
@Champnet
I would agree, not always, but in a simple setting they usually are.
thejudge
Thanks dave. mine at least seems to be OK now.
steed
Mine seems to be working OK now.
Thank you for solving the issue.
Lordwotsit
Our site is indeed working now. Thanks all who contributed and the staff @dave for actioning the fix 👍🙂
BTW do we get a discount on our charges for doing our "bit" for the company 😉
