my webspace
andrewbillen
my webspace
Hi
I have successfully uploaded a soundfile to my plusnet webpage into index.htm but I cannot access my web page by internet. It says it has not been uploaded. Does anyone know ho to mkae the first page of my site index.html? Thanks for any help.
Andrew Billen
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: my webspace
I've just had a quick look at your site and you haven't uploaded an index.html file which is why it's defaulting to the Plusnet one. You need to save the homepage of your site as index.html and then upload this inside the htdocs folder.
andrewbillen
Re: my webspace
Thank you very much. The next question is how do I do that?
Andrew
geewizz
Re: my webspace
When you save the file, instead of saving it as "index.htm" save it as "index.html". Alternatively, rename the file on your hard disk by right-clicking on it and selecting "rename". Then upload it to the server.
