my webspace
- Everything else
- Re: my webspace
my webspace
02-07-2008 10:25 AM
Hi
I have successfully uploaded a soundfile to my plusnet webpage into index.htm but I cannot access my web page by internet. It says it has not been uploaded. Does anyone know ho to mkae the first page of my site index.html? Thanks for any help.
Andrew Billen
Andrew Billen
Message 1 of 4
(1,552 Views)
3 REPLIES 3
Re: my webspace
02-07-2008 10:29 AM
I've just had a quick look at your site and you haven't uploaded an index.html file which is why it's defaulting to the Plusnet one. You need to save the homepage of your site as index.html and then upload this inside the htdocs folder.
Message 2 of 4
(430 Views)
Re: my webspace
02-07-2008 10:38 AM
Thank you very much. The next question is how do I do that?
Andrew
Andrew
Message 3 of 4
(430 Views)
Re: my webspace
02-07-2008 11:34 AM
When you save the file, instead of saving it as "index.htm" save it as "index.html". Alternatively, rename the file on your hard disk by right-clicking on it and selecting "rename". Then upload it to the server.
Message 4 of 4
(430 Views)
