my cron job seems to have stopped running
- Everything else
- my cron job seems to have stopped running
25-04-2011 11:09 AM
I have a backup script that is run by CRON. For someone unknown reason it has stopped running. The script itself is fine as I can run it manually no bother.
As all CRON entries are now under the control of PN Networks, I raised a ticket via the 'Ask a question of the Support team' with a reply of 'Unfortunately this is not something we can offer direct support on', and suggested I raise it here.
(http://usertools.plus.net/tutorials/id/18 #Backups and http://community.plus.net/forum/index.php/topic,84740.msg741300.html#msg741300 both suggest you raise a ticket).
So does anyone have any advice on how to raise CRON issues, specifically who they are sent to and who deals with them.
thanks
Hope I don't get into a 'raise a ticket, raise on forum,raise a ticket...' stack overflow !
thanks
Message 1 of 2
(632 Views)
1 REPLY 1
Re: my cron job seems to have stopped running
27-04-2011 10:23 AM
Hi Marku,
It looks like this has been picked up for you, I'm sorry for the delay. I've had a word with the agent concerned as this is something our networks team can do for you (indeed it has now been done).
Message 2 of 2
(83 Views)
- Everything else
