mx records for a subdomain
- Everything else
- mx records for a subdomain
13-10-2014 12:55 PM
I am in the process of deploying a new mail server and I want to test it by sending test mail to a sub domain but the remainder of the mail should still be sent to the existing server. We have multiple broadband lines so we have a few static IPs.
My intention is to point a sub domain of our hosted domain at a static IP which is routed to the new server, however I am not sure my DNS entries are correct, is the correct? It feels as if there should be more to the second mx record.
myhosteddomain.co.uk.
Left field Type Pri Right field
mail1 a x.x.x.100
mailtest.myhosteddomain.co.uk. a x.x.x.120
mx 20 mail1
mx 30 mailtest.myhosteddomain.co.uk.
mail1 a x.x.x.100
mx 20 mail1
Message 1 of 4
(989 Views)
3 REPLIES 3
Re: mx records for a subdomain
13-10-2014 1:04 PM
That looks fine to me.
Edit: I misinterpreted what it is you're trying to achieve. You need a 'mailtest' on the left hand side of the final MX record. It's a tad irrelevant, but the record needn't be a lower priority than mail1 either.
mail1 A x.x.x.100
mailtest A x.x.x.120
MX 20 mail1
mailtest MX 20 mailtest
Message 2 of 4
(292 Views)
13-10-2014 1:31 PM
Bob, thanks. I hadn't appreciated that the left field for mail1, because it is blank, is actually pointing at the hosted domain name.
Presumably using FQDN it would read
myhosteddomainname.co.uk. MX 20 mail1.myhosteddomainname.co.uk.
Message 3 of 4
(292 Views)
13-10-2014 2:17 PM
Yep, that's right. Any record that's not 'qualified' with a trailing dot, will have myhosteddomainname.co.uk appended to it.
Message 4 of 4
(292 Views)
- Everything else
