mod_rewrite revisited
- Everything else
- mod_rewrite revisited
07-10-2010 11:33 AM
I have a domain hosted by PlusNet and pointing at the ccgi server, and I want to use mod_rewrite directives in .htaccess to point at a domain-specific subdirectory.
Thanks to previous assistance in here I had this working with the following:
However, it seems not to be working now and is raiseing:
[tt]Internal Server Error The server encountered an internal error or misconfiguration and was unable to complete your request.[/tt]
It's a while since I looked at it, so I'm wondering if it's perhaps a difference in the new ccgi platform?
I've installed WAMP on my own machine to try to track the problem down, but it seems to work as expected there. Any suggestions on how to fix it, or tips on how to debug such problems?
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_URI} !^.*/[^/]+\.[^/]+$
RewriteRule ^(.+[^/])$ $1/ [R,L]
RewriteCond %{HTTP_HOST} ^(www\.)?mydomain\.co\.uk$ [NC]
RewriteCond %{REQUEST_URI} !^/folder/
RewriteRule (.*) /folder/$1
Message 1 of 6
(960 Views)
5 REPLIES 5
Re: mod_rewrite revisited
07-10-2010 2:00 PM
The last 3 lines are probably looping on new ccgi.
I think the line
needs to be
See here.
I think the line
needs to be
RewriteCond %{REQUEST_URI} !^/~username/folder/
See here.
David
Message 2 of 6
(215 Views)
08-10-2010 6:09 PM
Excellent - thanks very much, that seems to have fixed it. In doing that I screwed something else up somewhere such that, in a subdirectory below /folder, referenced files don't seem to be properly rewritten so .css isn't working etc. I'll have a trawl, but if this is a common 'gotcha' with a simple solution, a pointer in the right direction would be most appreciated
Thanks again.
Thanks again.
Message 3 of 6
(215 Views)
09-10-2010 12:53 AM
I suspect the presence of /~username might be upsetting things here too. Is it PHP code that is generating the subdirectory references?
David
Message 4 of 6
(215 Views)
09-10-2010 10:59 AM
No, the pages I've looked at so far have just been plain HTML files with simple references, e.g.:
... etc.
link href="styles.css"
form action="search.php"
... etc.
Message 5 of 6
(215 Views)
09-10-2010 1:20 PM
Hmmm... I've got it working now. The problem turns out to have been with another .htaccess file I have in the subdirectory so was nothing to do with the ~username change. I was rewriting a filename for backward-compatibility, but I seem to need to redirect in order to get the css files etc. to work:
Out of interest, can anyone explain to me why it has to be a Redirect in order to work? It's not really important in this case, but it could be in other cases where I might not want to have the actual URL appear in the browser's address bar.
RewriteCond %{REQUEST_URI} oldname/$ [nc]
# RewriteRule .* newname.htm// Works, but unqualified links to other files in same directory fail
RewriteRule .* newname.htm [R,L] // Works, and links are honoured
Message 6 of 6
(215 Views)
