mediawiki software installation issue
- Everything else
- mediawiki software installation issue
03-03-2008 1:46 PM
Hi. I'm having issues with installing the media-wiki software in my ccgi space. I'm following the instructions at http://www.mediawiki.org/wiki/Manual:Downloading_MediaWiki although also referencing http://community.plus.net/forum/index.php/topic,45441.msg388708.html#msg388708
So I've run chmod 750 config, skipped the database creation and gone to my config page to be told that:
So I'm stumped. Do plusnet have PHP version 5.0 or later? Would that be the issue? Sorry of this is something really obvious.
Quote Execution of (index.php) is not permitted for the following reason:
Script is not executable. Issue 'chmod 755 filename'
Message 1 of 6
(1,460 Views)
5 REPLIES 5
Re: mediawiki software installation issue
03-03-2008 1:48 PM
The ccgi server does not support PHP5.
You need to telnet to ccgi.plus.net and login to the command shell and run fixphpperms.sh -r to set the correct permissions on php files.
Message 2 of 6
(342 Views)
03-03-2008 2:05 PM
Thank you Peter, that's got me through that step. What does that command do and did I miss being told to do it somewhere, if you don't mind me asking?
Message 3 of 6
(342 Views)
03-03-2008 2:06 PM
Ah, I need to install the version that works on php 4. Whoops.
Message 4 of 6
(342 Views)
03-03-2008 2:58 PM
The script just recursively (the -r parameter) finds all .php files and changes their file permissions to be correct for running on plusNets secure ccgi webservers.
It is explained in the help & support pages for CCGI here
Message 5 of 6
(342 Views)
03-03-2008 3:03 PM
Ah, thank you.
Message 6 of 6
(342 Views)
- Everything else
