mb_string disabled?
- Everything else
- Re: mb_string disabled?
mb_string disabled?
22-12-2007 10:54 AM
Is mb_string (mbstring) function disabled at PlusNet?
In my cms a charset-translation is calling on that php-function but gets the response:
Fatal error: Call to undefined function: mb_convert_encoding() in /path/to/file/of/ffupi/mydirectory/mycms/subdirectory/more/more/thisisthephpfile.php on line 134
If it is disabled, can it be switched on by including into the php-file:
--enable-mbstring
... and how is that done?
In the php-help at http://de3.php.net/manual/en/ref.mbstring.php it explains that this function is not enabled by default.
Something like that:
<?php
// Enable mb_string for this php-file
mbstring enable;
....bla..bla..php-code
--enable-mbstring
<?php
mbstring enable;
Message 1 of 7
(2,314 Views)
6 REPLIES 6
22-12-2007 5:34 PM
You can check if "mb_string" is disabled with PHPInfo();
Scroll down, if it is enabled it would display a large bold title "mb_string",
and possibly a table for configuration.
also, don't you mean:
unless 'dl' is also disabled
to do what you're asking, you would probably have to do something like:
system('php --enable-mbstring file.php",$return);
to enable PHP to properly pickup CL stuff,
no way can a currently running PHP manipulate the CL its parsed from the Web Server.
it's a pain in the proverbial because it's not always a practical solution with dynamic systems to have all sorts of messy bodges.
Hopefully something there helps... perhaps I have missed the point of what you're after...
Jim,
if(dl('php_mbstring.so")){
}else{
//error
Jim,
Message 2 of 7
(549 Views)
26-12-2007 3:34 PM
Hello
Thank you for the reply.
I have now amended the phpinfo.php file as follows:
However, this does not work. The error message is:
Parse error: parse error, unexpected $ in /path/to/file/bla/ffupi/phpinfo.php on line 4
I then tried this:
It also does not work. The ini_set is just ignored.
The same with that:
Any idea what the correct ini_set syntax is?
phpinfo()
I then tried this:
ini_set("mbstring", "enable");
phpinfo()
The same with that:
ini_set("mbstring.encoding_translation", "On");
phpinfo()
Message 3 of 7
(549 Views)
09-01-2008 1:44 PM
Any hope of an answer?
Message 4 of 7
(549 Views)
09-01-2008 2:27 PM
The option is a compile time selection, not a run-time selection. Also it needs an additional shared object library to be installed on the server containing the necessary functions which, if it were, would have been included in the compile/config of php anyway.
Message 5 of 7
(549 Views)
15-01-2008 11:55 PM
Hello
I have now put an Apache server on my memory stick and it runs the cms quite well. The php module mbstring is included.
Is there a problem to enable this module on a big server like PlusNet? I ask this because I received this answer from customer support:
On the memory stick I noted many more module enabled, than on PlusNet.
How shall I understand this?
Quote I have put forward your request to add this module. We will look into adding this if there are enough customers requesting it. Please let us know if you have any further queries.
Message 6 of 7
(549 Views)
16-01-2008 8:31 AM
This module was never enabled on our systems at compile time. The reason why, I do not know.
Because of the nature of the service, it is not simple to simply compile this module in.
It has to be done as a carefully thought out project, to ensure that this module is not going to break backwards compatibility, ensure that the module is stable and not going to create problems with the service and other factors.
How long this would take or if it would happen, is unknown as it would depend on the number of requests and other items on the workstack.
Message 7 of 7
(549 Views)
- Everything else
