logging in to put a php file in cgi
iancash
Hi Guys,
I currently use the http://homepages.plus.net/cgi-bin/form web form but I think I have cgi access, so want to use my own one, mainly becuase I dont like the 'thank you' page
I activated my cgi and sql
can I use my standard vista windows explorer to put my php file in my own cgi location?
if have tried typing the following into windows explorer and internet explorer address bar
ccgi.username.plus.com
ftp://ccgi.username.plus.com
cshell.plus.net
ftp://cshell.plus.net
(yes i changed username ha ha)
none of which give me a login screen or do anything really
what am i doing wrong?
thanks
13 REPLIES 13
iancash
Re: logging in to put a php file in cgi
i've been trawling the forum looking for answers.
i'm on a laptop connected to the internet via virgin.
am i right to think i need to be on a PC connected to the internet via plusnet in order to access ftp cgi ?
if so, when i eventually get to that PC, what is the full ftp address i need for windows explorer including the ftp bit
many thanks
spraxyt
Resting Legend
Fixes: 75
You do have to be on a Plusnet connection to access your ccgi space, and either of the ftp:// forms should work (you will be asked for username and password). However uploaded PHP files must not be in cgi-bin and they have to be made executable (permissions 0700).
If you want to use a browser, in my opinion using Firefox with the FireFTP plug-in is a much easier way to transfer and manage your files.
David
iancash
Quote from: spraxyt
oh, where do i have to put them?
jelv
Fixes: 10
Quote from: iancash
Do you have a Plusnet broadband account?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
spraxyt
Resting Legend
Fixes: 75
Quote from: iancash
Anywhere except in the cgi-bin folder.
David
iancash
My dad has the plusnet broadband account at his house, and he pays for plusnet to host his domain.
I am building his website remotely from my flat.
I have built the whole site now using windows explorer ftp to upload the files.
I want to put a contact form on his website. The one i found was this one http://www.tele-pro.co.uk/scripts/contact_form
it gives me the html and php code.
I saved the html code into a blank web page, and saved the php code as a php file using notepad.
i put them all in the same directory, but when i complete the form and click submit it goes to a 405 programming error.
what am I doing wrong?
many thanks
jelv
Fixes: 10
Quote from: iancash
Putting php files on a web server that doesn't support PHP.
PHP is only supported on the CCGI servers.
http://www.plus.net/support/webspace/cgi_php/index.shtml?supporta=cgi
iancash
sorry, i'm sure this is frustrating to you.
so where do i upload my php file to???
in lamen ftp address form lol
jelv
Fixes: 10
Have you activated the CGI service as described in the help pages I linked - if you haven't you can't use PHP. If you have read those pages you will have seen:
FTP
You can view your CGI space using an FTP program at the following address:
      FTP address: ccgi.username.plus.com
      Port: 21
      Username and password: same as you use for accessing the Member Centre.
Use FTP access for transferring scripts and webfiles. Most FTP software will also allow you to change file permissions.
More help with using FTP
iancash
as per my original post I have activated cgi
i cannot get on the cgi webspace from this computer, all i want to know is when i eventually get onto my dads computer - where should I put the php file.
do i just go to
log in and then make a subfolder called anything and put it in there?
is this "cgi-bin" a default folder within ccgi.username.plus.com
or is ccgi.username.plus.com itself the cgi-bin?
Embarrassed
jelv
Fixes: 10
The ftp is correct. CCGI is a totally different server (in fact the homepages servers where you will have loaded content so far are in Sheffield and the CCGI servers are in London!) References to php files from homepages need to give the full URL.
Don't put php files in the cgi-bin directory (or create any directories inside there) - they either go in the main directory or you need to create directories in there.
Gabe
Probably a bit late to mention this, but if anyone does want to use the homepages script without users seeing the default response page, you can set your own:
<input type=hidden name="redirect" value="http://www.username.plus.com/foo/bar.html">
Gabe
iancash
Quote from: Gabe
Gabe
it's not late at all. you are a legend. i'm sorted now. thank you very much  Smiley
