logging in to ccgi
stuck
logging in to ccgi
I found this tutorial:
  http://usertools.plus.net/tutorials/id/50
about how to install Gallery  on the CGI server.  I'm a complete novice at twe sites but I have been around PCs for a long time and so wasn't in the least bit phased by the tutorial, it looks straight forward.
When I can to try it though I found I got stuck  very early on, at the bit where it says "log on to the CGI Server using telnet."
When I enter "telnet cshell.plus.net" at a command prompt on my PC it responds with 'invalid command'.
I can use an ftp client (coreFTPlite) and see the cccgi webspace and I can use the client to upload files but how do I run a chmod command?
Please go very sloooooooow and gentle when you reply, I mean think really basic pell everything out.  I'm not stupid but cgi is completely new to me.
stuck
5 REPLIES 5
jelv
Fixes: 10
Re: logging in to ccgi
telnet was disabled over a year ago.
You need to extract the full directory structure on you local PC and then upload that.
Alternatively http://community.plus.net/library/tools/using-any-shell-command-in-cron/ gives a method for using cron to unpack the files on the server.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
spraxyt
Aspiring Legend
Fixes: 75
If you want to unpack an installation file on ccgi you can do it using a bash script as described in this post.
This topic discusses setting the correct permissions on directories and executable files, and provides a script to do this..
David
stuck
Thank you for these hints.  I'm out of monthly allowance right now + I'm only trying this out of curiosity not need, so it may be a while before I get another go at this task.
I'm fairly sure I'll be back, I didn't pick my user name at random  Wink
stuck
Boxersoft
I'm not familiar with that FTP client but others I've used (currently FileZilla) provide the means to set file permissions. Try right-clicking a file on the server side and see if you get a popup menu exposing something that looks promising.
stuck
Quote from: Boxersoft
Another helpful hint, thanks.  Yes coreFTPlite does allow me to set file permissions, I stumbled across it when following the hints above about creating and using a permissions.cgi file.
stuck
