iPlayer stutters under Chrome; YouTube ok, iPlayer on Edge ok - ideas?
gramachree
Starting earlier this week I had video problems on my year old ASUS laptop.
With lots of jigging and poking (cleared Chrome, updated drivers, ddtc.) I am down to iPlayer stuttering when playing under Google Chrome.
YouTube under Chrome plays nicely. iPlayer on Edge plays nicely.
All ideas gratefully misunderstood and misapplied.
3 REPLIES 3
Fixes: 418
Re: iPlayer stutters under Chrome; YouTube ok, iPlayer on Edge ok - ideas?
Have you looked at disabling Chrome extensions or better still removing it and installing a fresh copy?
gramachree
I was just about to try your suggestion when I stumbled upon the answer.
This morning I was editing some photographs in Adobe Lightroom Classic and had the spinning wheel syndrome in the Develop module. The official Adobe line is to try turning off hardware acceleration. I did that and it fixed my Lightroom problem - and I could feel no difference in performance.
So, expecting this solution to fail for Chrome, I turned off hardware acceleration in Chrome - and the problem went away. iPlayer works just fine. (DirectX: NVIDIA GeForce MX150 (26.21.14.3086))
Thank you for your interest.
gramachree
Indeed, further investigating this I have been able to re-enable my graphics card with everything still working! iPlayer works with acceleration and Lightroom works with acceleration.
The hint lay in item 7 of https://helpx.adobe.com/uk/lightroom-classic/kb/lightroom-gpu-faq.html#gpu_driver_troubleshoot.
In Device Manager | Display adapters I disabled my Intel driver allowing the Nvidia driver to take precedence.
