iCloud private relay
Minxymoo
It would appear that Plusnet doesn’t support iOS 15’s new iCloud private relay.
12 REPLIES 12
Mook
Seasoned Champion
Fixes: 9
Re: iCloud private relay
@Minxymoo You're basing this on what might I ask?
Minxymoo
Based on the fact that when I turn it on I can not view any websites.
Mook
Seasoned Champion
Fixes: 9
Ah, it's evidently working too well. Do have an existing VPN?
Minxymoo
Yes my existing VPN works fine.
Mook
Seasoned Champion
Fixes: 9
Won't you need to disable that first, as private reply is in essence a VPN.
Minxymoo
Tried that, made no difference.
Fixes: 1,491
Moderators Note
This topic has been moved from ADSL Broadband to Everything Else
Fixes: 1,491
Seems to be working for me at the moment.
Sometimes it works and sometimes it doesn't, I have a theory that sometimes it's using IPv6 which doesn't work on the PN network.
Minxymoo
Do you have Safe Guard turned on?
Fixes: 1,491
Nope, off here.
Minxymoo
I’ll give that a try.
Minxymoo
Seems to work with SafeGuard off.
