.htpasswd file location
- Everything else
- .htpasswd file location
17-07-2011 6:43 PM
Hello,
I am intending to password protect a section of my website using .htaccess/.htpasswd files. I have done this previously with a different ISP placing the .htpasswd file below the root directory. The advice I was given at the time was "For security, you should not upload the htpasswd file to a directory that is web accessible (yoursite.com/.htpasswd), it should be placed above your www root directory." I was able to do this, though I cannot recall quite how.
It seems logical for security to keep the password file out of harms way but I have not found any comment on this issue in the forum. Are my concerns misplaced?
How would I go about placing a file below my root directory?
Regards
Stefan
Regards
Stefan
Message 1 of 2
(988 Views)
1 REPLY 1
Re: .htpasswd file location
17-07-2011 8:37 PM
Password protecting folders is explained in the Community Support Library article How to password protect your website.
On Homepages the web root folder is /htdocs and / is physically above that. On CCGI the web root is / and no locations available to the user are above it. In either case Order, Allow and Deny directives can be used to control web access to a particular folder.
David
Message 2 of 2
(348 Views)
- Everything else
