.htaccess
- Everything else
- .htaccess
.htaccess
13-10-2012 1:50 PM
This is an odd one
In my Plusnet site (not ccgi) I can view the files in a folder where there isn't an index file.
I seem to remember that this is done via the .htaccess file but using FireFTP with show hidden files ticked I can't see it
The reason for this question is that creating a new folder in my 1&1 hosted site produces a folder with the following error on trying to access it but I can access the files inside it
Quote Forbidden
You don't have permission to access /ramblers/ on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Message 1 of 6
(2,348 Views)
5 REPLIES 5
Re: .htaccess
13-10-2012 2:46 PM
I'm not clear if you want to stop viewing files on homepages or start viewing files on 1&1. The new folder on the 1&1 site is presumably missing its read permission for the web server. If you tick all the read permissions, you should be able to view the files on 1&1. Alternatively, untick the read permission for "other" on homepages to stop viewing files. Or add a .htaccess file with the line
to htdocs to avoid triggering the error.
Gabe
IndexIgnore *
Gabe
Message 2 of 6
(271 Views)
Re: .htaccess
13-10-2012 3:18 PM
Regarding permissions this is what they are and I can't see why I can't view the list of files in the folder
The idea being that you can go to the folder select and download the file you need
Message 3 of 6
(271 Views)
Re: .htaccess
13-10-2012 3:37 PM
If not permissions, may need to add indexing. There may be a box to tick for indexes in your panel, or you can try adding
to your .htaccess
Gabe
Edit: just found it in the 1&1 FAQ.
Options +Indexes
to your .htaccess
Gabe
Message 4 of 6
(271 Views)
Re: .htaccess
13-10-2012 3:45 PM
Thanks Gabe but I think I will leave well alone as I don't want to risk mucking up my wife's website
as she would kill me
The only reason I used her website instead of mine was that 1&1 have an unlimited download limit whereas we all know how miserable the Plusnet limits are and I needed to make a 280MB zip file available for download - most unusual for me
I saw your edit and yes that would do it - I didn't realise that you could have htaccess files specific to a folder - just going to have a play
and it works - thank you very much
Message 5 of 6
(271 Views)
Re: .htaccess
13-10-2012 4:08 PM
That's a relief. I hadn't appreciated the risk you were running
Gabe
Gabe
Message 6 of 6
(271 Views)
