.htaccess in ccgi space
- Everything else
- Re: .htaccess in ccgi space
08-06-2008 12:16 PM
Hi
I have a .htaccess file to password protect a directory in my ccgi space, but it only works if the URL has no trailing slash - eg
http://ccgi.MYUSERNAME.plus.com/cgi-bin/test
forces the password request dialog to be shown. But
http://ccgi.MYUSERNAME.plus.com/cgi-bin/test/
just shows the default page (in this case index.php) without requesting a password. If there is no default page, then the password is always requested.
Plusnet support have offered a few solutions - playing with the path in the .htaccess file etc, but with no success.
Any ideas?
Cheers
Phil
Any ideas?
Cheers
Phil
Message 1 of 5
(2,428 Views)
4 REPLIES 4
08-06-2008 3:39 PM
You cannot use .htaccess to protect .php files on the ccgi server as .php files are accessed outside of the Apache web server and thus .htaccess has no effect.
Message 2 of 5
(611 Views)
08-06-2008 3:51 PM
Thanks.
So, is there any automatic way of password protected cgi stuff? I only need single user access to a certain part of the site. If there isn't, then I'll write some user management stuff; just don't want to re-invent the wheel.
Cheers
Phil
Cheers
Phil
Message 3 of 5
(611 Views)
08-06-2008 9:42 PM
Start writing
or perhaps look at some of the existing user management scripts on www.hotscripts.com
Message 4 of 5
(611 Views)
09-06-2008 9:14 AM
Thank 🙂
Message 5 of 5
(611 Views)
- Everything else
