htaccess for 301 from .co.uk to .com not working
- Everything else
- htaccess for 301 from .co.uk to .com not working
25-11-2008 1:26 PM
Hi all
I am having some problems with a htaccess used to redirect .co.uk to .com
Both .co.uk and .com are pointed via dns at the same folder in the ccgi server. I am using this following script:
Options +FollowSymlinks
RewriteEngine on
rewritecond %{http_host} ^www.domain.co.uk [nc]
rewriterule ^(.*)$ http://www.domain.com/$1 [r=301,nc]
But what is happening is that http://www.domain.co.uk/ is returning HTTP 200 OK
but the stylesheet and images are correctly being returned with a 301,
which then returns the new .com correctly as a HTTP 200 OK
So in the url address bar has the .co.uk, with associated file being served from the .com
Not ideal
Does anyone have an idea why this is not working correctly?
Ta
RewriteEngine on
Not ideal
Ta
Message 1 of 3
(880 Views)
2 REPLIES 2
Re: htaccess for 301 from .co.uk to .com not working
25-11-2008 1:35 PM
Hmm,
That should do it - it will rewrite the query string too, if your site uses them.
B.
Options +FollowSymLinks
RewriteEngine on
rewritecond %{HTTP_HOST} ^www\.domain\.co\.uk [NC]
rewritecond %{QUERY_STRING} ^(.*)$
RewriteRule ^(.*)$ http://www.domain.com/$1?%1 [R=301,L]
B.
Message 2 of 3
(312 Views)
25-11-2008 1:41 PM
I have changed and uploaded the htaccess file, but the redirect is not working for php files.
Css, and images are being redirected correctly.
Is there anything I can do to get it working on the php files?
Message 3 of 3
(312 Views)
- Everything else
