.ht access redirect with GET data
- Everything else
- .ht access redirect with GET data
05-01-2008 9:55 AM
I wonder whether anybody here can help me out. I'm sure I'm being stupid, but I just can't figure this one out.
All I want to do is to redirect
I would have thought that something like these two lines would work:
The only way that I can find to do it is:
This passes the ?id data from link.php to linkredirect.php, and then use PHP's Header function to redirect to the page that I want.
Surely there must be an easier way than this. If anybody can help, I'd appreciate it.
PS: Is there another way to stop the forum code from automatically changing URLs into <a> tags, apart from using the CODE tag?
www.mydomain.co.uk/link?id=nto
www.mydomain/link/n(where n is a number).
Redirect 301 /old_dir/link.php?id=([0-9]+)$ http://www.mydomain.co.uk/link/$1
RewriteRule ^old_dir/link.php?id=([0-9]+)$ http://www.mydomain.co.uk/link/$1
Redirect 301 /old_dir/link.php http://www.mydomain.co.uk/linkredirect.php
Message 1 of 3
(2,209 Views)
2 REPLIES 2
Re: .ht access redirect with GET data
07-01-2008 9:31 AM
Thank for your suggestion about bad bot lists.
Er, I'm still going up the learning curve, but a) I recall reading somewhere that redirect isn't the best way to do this (more appropriate for temporarily or permanently moving whole sites, where it has the advantage that search engines record the new addresses) and b) I also recall reading about the use of mod_rewrite to achieve this sort of thing. Amongst other possible options, a line 'Rewrite Engine On' is necessary directly above the RewriteRule(s), though this isn't always included in examples. (I read it as meaning something like, "rewrite on the following conditions:".
As you presumably don't have the string 'id=' in the domain portion of the address, it ought to be straightforward to write a rule that simply strips these 3 characters out before handing on the modifed address; with [NC] or whatever the option is to ignore case. Wikipedia has a list of useful sites at the end of the Rewrite Engine (aka Mod_Rewrite) page.
Of course we don't know for sure whether PN allows the use of mod_rewrite.
Message 2 of 3
(252 Views)
08-01-2008 11:28 AM
Pretty sure it is allowed - I'm sure I've used it in the past for a couple of bits and bobs.
Message 3 of 3
(252 Views)
- Everything else
