how to block a computer or phone from connecting to wifi USING PLUSNET PROTECT
- Everything else
- how to block a computer or phone from connecting t...
20-12-2020 7:22 PM
I have tried doing this on the plusnet hub , but when it resets then this is knocked off , i have free trial of the mcAfee plusnet protect , but can't see how to block devices on there
Re: how to block a computer or phone from connecting to wifi USING PLUSNET PROTECT
20-12-2020 7:46 PM
Moderators Note
This topic has been moved from Chat to Everything Else
20-12-2020 8:20 PM
20-12-2020 8:57 PM
@daveplus . yes , but , as i said , when the router is reset , which my child does everytime I set up restrictions using access control, the settings go back to default, which is why I am asking how to do it using PLUSNET PROTECT
20-12-2020 9:24 PM
Then when the router is reset it'll go back to the original - result no access when reset.
20-12-2020 9:33 PM
@Bogbody . great idea - how do i change default password ?
21-12-2020 7:39 AM
Exactly how depends on the individual router.
What model is it? Ask on here for advice.
2 weeks ago - last edited 2 weeks ago
2 weeks ago
How old is your child?
As for the router, if its a plusnet router once re-set it should re-connect as they are pretty basic plug in and go devics.
if you have a consumer non plusnet router, once re set to factory defaults then it will need you ( or someone) to r-enter the plusnet connection details.
You could also try moving the router/ hidinif over 10 g it somewhere, altough the effect of this will depend upon how old the child is, if over 10 then it will most likely be found
- Everything else
