how can I trace where the website address got broken?
- Everything else
- Re: how can I trace where the website address got ...
22-07-2009 4:39 PM
I have a domain registered with an external company - and had them point their name servers at plusnet so I could 'transfer in' the domain to my plusnet account.
In the domain hosting settings on plusnet the dns records for my domain have been configured to:
left field: www
Type: cname
right field: ghs.google.com.
This allows my www sub-domain to point at my google sites web space - after associating the domain name within the google sites settings too.
This all worked wonderfully - I could view the web space on google sites using the address of my domain without any problems ... but in the last couple of days I can't - it shows up as a broken link
What I want to know is: can anyone recommend any web tools for determining where in the chain this problem has occurred?
I can quite easily check my plusnet dns settings and the google sites settings required - and they haven't changed. I don't know how to see what the name servers of the (external) registrar are pointing at so I'm suspicious of that - but would like to verify the cause of the problem before I send off an email to their customer support ... and preferably be able to attach a log file output to prove that they are the problem ...
Thanks,
Alan
Re: how can I trace where the website address got broken?
22-07-2009 5:04 PM
22-07-2009 5:07 PM
Thanks for that - I'll contact the registrar.
22-07-2009 5:11 PM
22-07-2009 5:12 PM
22-07-2009 5:14 PM
Quote www.solarscience.ie. CNAME IN ghs.google.com.
ghs.google.com. CNAME IN ghs.l.google.com.
ghs.l.google.com. A IN 74.125.93.121
l.google.com. NS IN a.l.google.com.
l.google.com. NS IN b.l.google.com.
l.google.com. NS IN d.l.google.com.
l.google.com. NS IN e.l.google.com.
l.google.com. NS IN f.l.google.com.
l.google.com. NS IN g.l.google.com
Which look OK to me and point the problem to Google.
22-07-2009 5:16 PM
Quote from: Strat No nameservers listed for solarscience.co.uk on http://ferret.centralnic.com.
Because it's not co.uk but ie
22-07-2009 5:20 PM
23-07-2009 12:31 PM
I removed www.solarscience.ie from the web addresses in the google sites settings, then put it back in and it's fine now.
Thanks for all the help on this - I know a bit more about this stuff now
23-07-2009 2:13 PM
Using http://www.hscripts.com/tools/HDNT/dns-record.php
I get the following for arcticgiraffe.com
Quote Domain Type Class Result
arcticgiraffe.com. A IN 194.154.164.82
arcticgiraffe.com. NS IN ns2.hosteurope.com.
arcticgiraffe.com. NS IN ns.hosteurope.com.
ns.hosteurope.com. A IN 212.67.202.2
ns2.hosteurope.com. A IN 212.67.203.246
and if I try www.arcticgiraffe.com I get
www.arcticgiraffe.com. CNAME IN ghs.google.com.
l.google.com. NS IN g.l.google.com.
But solarscience.ie gives the following for solarscience.ie
Quote No A records exist for solarscience.ie
and as someone above pointed out - for www.solarscience.ie
Does this mean that the solarscience.ie domain only has the www sub domain available to me? Is this common? Are there some articles that I can look at that explain the ins and outs of domains and sub-domains and what I can use, or not ...
At the moment in my plusnet domain names settings the following domains are listed
Quote Domain Name solarscience.ie
Status Registered and Hosted
Domain Name giraffeandtiger.co.uk
And in the settings for both domains I have the following
Quote I wish to specify DNS records for hosts under this domain
Additional DNS records (Advanced)
Left field Type Pri Right field
mx 20 mx.last.plus.net.
www cname ghs.google.com.
If I added an additional record could I have anything I like in the Left Field?
So I could have a site http://wibble.arcticgiraffe.com ?
23-07-2009 2:19 PM
23-07-2009 4:56 PM
| Left | Type | Right |
| solarscience.ie. | A | 74.125.93.121 |
- Everything else
