homepages.force9.net websites
- Everything else
- homepages.force9.net websites
13-02-2011 8:03 PM
Is there an issue with homepages.force9.net websites (yes, I know it's an old method of accessing)... It's just that today it no longer seems to work?
The website http://www.king1.force9.co.uk/index.htm works, but not http://homepages.force9.net/king1/?
Cheers,
Nick
Re: homepages.force9.net websites
13-02-2011 8:24 PM
13-02-2011 8:27 PM
For example, you supplied two different addresses that will access two different files.
Equal to
http://homepages.force9.net/king1/index.htm
Equal to
You have an index.html as well as index.htm. index.html take priority in search order over index.htm
13-02-2011 8:54 PM
Earlier on today, the site wasn't even working - has something been altered today?
Cheers,
Nick
13-02-2011 8:57 PM
(Edit: It seems intermittent)
Cheers,
Nick
13-02-2011 9:48 PM
How often do you see the issue?
Is there any gaps between problems?
What exactly do you see, when you see the problem?
The last page you listed works for me.
13-02-2011 9:57 PM
The requested URL /king1/ [which varies] was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache Server at homepages.force9.net Port 80"
It's been intermittent all day - regardless of where I've been (three seperate ISP's)...
Cheers,
Nick
dick:quote
13-02-2011 9:58 PM
Between the three locations, is the same machine you bare using?
What browser are you using?
Have you tried an alternate one?
The last URL you pasted, is that copied and pasted direct from the address bar as and when the problem happens?
13-02-2011 10:09 PM
Haven't tried using IE yet (version 6.0 is on the laptop - for work purposes, so I don't bother using that if I need to do anything on the internet!), and IE is on the desktop (version 8.0), so I could try that?
As for the URL, I keep trying different random URLs from my webpage - manually typed.
Try http://homepages.force9.net/king1/News.html
"Not Found
The requested URL /king1/News.html was not found on this server.
Cheers,
Nick
dick:quote
13-02-2011 10:21 PM
It worked fine on Saturday - what's happened in the meantime?
Cheers,
Nick
13-02-2011 10:26 PM
I can't login to check for you unfortunately, however if you login via FTP with a client that can display hidden files (i.e not Internet Explorer), do you see a file in the "htdocs" directory called ".htaccess"?
13-02-2011 10:41 PM
13-02-2011 10:49 PM
Oh, no .htaccess file - logging in either via DOS (Command Prompt) or via CuteFTP.
Cheers,
Nick
dick:quote
13-02-2011 10:56 PM
13-02-2011 11:00 PM
Cheers,
Nick
dick:quote
- Everything else
