hit counter
- Everything else
- hit counter
hit counter
11-07-2012 5:22 PM
Re: hit counter
11-07-2012 6:48 PM
We do not operate web hosting facilities that supports Frontpage extensions and will as a result, display as a red cross indicating a missing resource within your page.
Re: hit counter
11-07-2012 10:20 PM
Re: hit counter
12-07-2012 3:39 PM
Many thanks, Mick
Re: hit counter
12-07-2012 3:41 PM
Many thanks, Mick.
Re: hit counter
12-07-2012 3:55 PM
The presence of the Frontpage icon is something I am currently investigating for removal from all accounts, due to the very confusion this has prompted yourself here.
I am currently undertaking investigation that simply removing it is not going to break anything else.
Re: hit counter
12-07-2012 8:15 PM
Re: hit counter
13-07-2012 10:53 AM
Best regards, Mick.
Re: hit counter
13-07-2012 1:43 PM
The counter should then appear on your page.
Re: hit counter
13-07-2012 4:07 PM
Best regards Mick
Re: hit counter
13-07-2012 7:24 PM
The existing hit counter code has a mangled reference to content on your own computer C: drive, but I doubt it would work on Homepages even if that was sorted out.
You don't need to install Webalizer to view your site's webstats. You do need to activate webstats first - have you done that? Then nothing will show until the next day when the webstats collection program has run; this automatically runs in the early hours.
Re: hit counter
14-07-2012 9:42 AM
best regards, Mick
Re: hit counter
14-07-2012 2:48 PM
Alternatively you could try turning them off, wait a day then turn them on again and check the following day. Up to you which route you want to try.
Re: hit counter
14-07-2012 7:50 PM
Re: hit counter
14-07-2012 7:54 PM
