help with uploading please
- Everything else
- help with uploading please
12-03-2008 6:19 PM
I use Core ftp and all was fine a while back when I last uploaded a file but now all I get is the status failed message.
This is the log...sorry if it goes on a bit & thanks for any advice.
Welcome to Core FTP, release ver 2.0, build 1507 (U) -- © 2003-2007
WinSock 2.0
Mem -- 1,047,852 KB, Virt -- 2,097,024 KB
Started on Wednesday March 12, 2008 at 18:14:PM
Resolving ftp.plus.net...
Connect socket #644 to 212.159.9.131, port 21...
220-PLEASE NOTE: If you have a non-subscription account you
220-will only be able to login to this ftp server if you are
220-dialled into our network.
220-
220-A Maximum of 4 concurrent connections are allowed to this
220-server, each session is limited to 64KB/s downloads and
220-32KB/s uploads.
USER starclipper
331 Password required for starclipper.
PASS **********
230 User starclipper logged in.
SYST
215 UNIX Type: L8
Keep alive off...
PWD
257 "/" is current directory.
PASV
227 Entering Passive Mode (212,159,9,131,200,12)
LIST
Connect socket #684 to 212.159.9.131, port 51212...
150 Opening ASCII mode data connection for file list
226 Transfer complete.
Transferred 63 bytes in 0.015 seconds
PWD
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (212,159,9,131,201,4)
STOR index.html
Connect socket #988 to 212.159.9.131, port 51460...
550 index.html: Permission denied
index.html - 0 bytes transferred
PASV
227 Entering Passive Mode (212,159,9,131,219,213)
LIST
Connect socket #988 to 212.159.9.131, port 56277...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (212,159,9,131,147,201)
STOR index.html
Connect socket #992 to 212.159.9.131, port 37833...
PASV
227 Entering Passive Mode (212,159,9,131,179,84)
LIST
Connect socket #992 to 212.159.9.131, port 45908...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (212,159,9,131,140,142)
STOR index.html
Connect socket #988 to 212.159.9.131, port 35982...
PASV
227 Entering Passive Mode (212,159,9,131,174,123)
LIST
Connect socket #1004 to 212.159.9.131, port 44667...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (212,159,9,131,188,220)
STOR index.html
Connect socket #1012 to 212.159.9.131, port 48348...
PASV
227 Entering Passive Mode (212,159,9,131,201,132)
LIST
Connect socket #1012 to 212.159.9.131, port 51588...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (212,159,9,131,165,64)
STOR index.html
Connect socket #1020 to 212.159.9.131, port 42304...
PASV
Transfer time: 00:00:02
227 Entering Passive Mode (212,159,9,131,143,105)
LIST
Connect socket #1096 to 212.159.9.131, port 36713...
Transferred 63 bytes in 0.016 seconds
WinSock 2.0
220-
220-32KB/s uploads.
USER starclipper
PASS **********
SYST
215 UNIX Type: L8
Keep alive off...
PWD
PASV
LIST
PWD
TYPE A
200 Type set to A
PASV
STOR index.html
PASV
LIST
TYPE A
200 Type set to A
PASV
STOR index.html
PASV
LIST
TYPE A
200 Type set to A
PASV
STOR index.html
PASV
LIST
TYPE A
200 Type set to A
PASV
STOR index.html
PASV
LIST
TYPE A
200 Type set to A
PASV
STOR index.html
PASV
LIST
Message 1 of 5
(1,271 Views)
4 REPLIES 4
Re: help with uploading please
12-03-2008 7:28 PM
The permission denied means it is not allowed to overwrite the index.html file. This should not happen.
Try deleting the file first via FTP then trying to upload t again.
If you get the same permission denied error uploading other files, you need to raise a ticket and get it looked at.
Message 2 of 5
(302 Views)
12-03-2008 8:02 PM
Thanks very much for the advice. If you mean deleting the file by right clicking & click delete - then it deletes for about two seconds and then re-appears again....
Message 3 of 5
(302 Views)
12-03-2008 11:38 PM
Sounds like a permissions problem with your webspace. Time to raise a ticket and get it investigated.
Message 4 of 5
(302 Views)
13-03-2008 6:54 AM
Thanks for the help
Message 5 of 5
(302 Views)
- Everything else
