ftp put creates empty file
- Everything else
- ftp put creates empty file
07-03-2014 10:49 AM
I frequently use a simple batch file incorporating a put command to upload a text file to my webspace. Until the new hosting arrangements it worked fine. Now all I get is an empty file in the webspace.
I know next to nothing about ftp command line, but have successfully logged on and tried entering a put command manually. I have ensured ascii mode, and tried PASV. Still the file uploaded is empty.
I can transfer the file successfully using CuteFTP, but it's a long-winded process compared to simply executing a batch file.
Can anyone suggest what's now going wrong, and how I can fix it?
Message 1 of 2
(2,421 Views)
1 REPLY 1
Re: ftp put creates empty file
07-03-2014 12:17 PM
Our server cluster doesn't appear to play nicely with active FTP and seems to require passive mode. Windows ftp.exe does not support passive mode. I'm almost certain this will be the cause of your problem. You'll see what I mean if you try FTP'ing from a command line and issuing a list (ls) command. It will stall and eventually time out.
Hostopia have a case open with their hardware vendors I believe because this behaviour isn't exhibited by their server estate in the US.
Message 2 of 2
(1,533 Views)
- Everything else
