ftp errors - anybody else?
longedge
Fixes: 4
Cumulus is throwing errors this morning typically error 530 (home directory not available) and timeout errors. I can log in without any problem using Filezilla. Is anybody else having any issues?
Just tried again before hitting post and I got "Error:    Critical error: Could not connect to server" from Filezilla.
32 REPLIES 32
longedge
Fixes: 4
Re: ftp errors - anybody else?
02/05/19 09:45:03 : FTP Connect Error, Error code = 530
02/05/19 09:45:33 : FTP Connect Timeout
02/05/19 10:00:04 : FTP Connect Error, Error code = 530
02/05/19 10:00:34 : FTP Connect Timeout
02/05/19 10:15:04 : FTP Connect Error, Error code = 530
02/05/19 10:15:34 : FTP Connect Timeout
02/05/19 10:30:03 : FTP Connect Error, Error code = 530
02/05/19 10:30:33 : FTP Connect Timeout
02/05/19 11:00:04 : FTP Connect Error, Error code = 530
02/05/19 11:00:34 : FTP Connect Timeout
02/05/19 11:15:03 : FTP Connect Error, Error code = 530
02/05/19 11:15:33 : FTP Connect Timeout
02/05/19 11:30:03 : FTP Connect Error, Error code = 530
02/05/19 11:30:33 : FTP Connect Timeout
02/05/19 11:45:04 : FTP Connect Error, Error code = 530
02/05/19 11:45:34 : FTP Connect Timeout
02/05/19 12:00:04 : FTP Connect Error, Error code = 530
02/05/19 12:00:34 : FTP Connect Timeout
02/05/19 12:15:03 : FTP Connect Error, Error code = 530
02/05/19 12:15:33 : FTP Connect Timeout
p.s. - I have been able to update my web page by selecting "web update" in Cumulus to do a full refresh of all the files. AFAIK this uses the same login credentials and mode as the 'normal' updates.
adamwalker
Fixes: 221
Hi there, that's odd! Error 530 usually means an incorrect password but I'm wondering if there's been a brief issue on our side as that's since worked for you. Sorry for any inconvenience in case it was.
 Adam Walker
Strat
Fixes: 565
My Cumulus has no errors recorded today and having done a manual upload it is fine.
longedge
Fixes: 4
@Strat  Can I ask what settings you use in Cumulus configuration/internet settings? I currently have active ftp mode checked.
I'm still getting the same error but have just done a manual update without any problem. Looks like the problem is at my end somewhere.
Strat
Fixes: 565
@longedge
longedge
Fixes: 4
@Strat  Thanks for that Thumbs_Up. I've removed active ftp and (for now) that seems to have fixed it. I can remember that I ticked it some time ago when I was having similar problems. Perhaps it's coincidence Smiley
longedge
Fixes: 4
Spoke too soon, I'm still getting the same error. I'll see what the next few days brings - perhaps it'll heal itself.
Jubby
All Star
Fixes: 31
Hello @longedge,
Could you confirm if you are using the details below to connect to FTP.
FTP: ftp.plus.net
FTP username: Your account username
Thank you.
 Lewis G
 Infrastructure Operations Professional
longedge
Fixes: 4
Yes I'm using the correct address, user and password, that's not the issue. In fact the last error was at 16:00 and the last auto update ar 17:00 (it's every 15 mins) so that's 4 updates on the trot successful. Perhaps whatever the problem was has cleared (said he with fingers crossed).
RandallFlagg
Fixes: 75
That's good to hear, @longedge - if this reoccurs, just give us a shout and we'll raise this to our network team on your behalf.
Best wishes
Dave
longedge
Fixes: 4
@RandallFlagg  Something weird is happening with all my Plusnet links and it seems to be password related. Cumulus connected OK at 0900hrs but since then is throwing a 530 error. Filezilla refuses to connect with 530 error.
My first attempt to log in to the forum took me to the registration page as if my details hadn't been recognised but a second attempt to log in was accepted. My forum password is different to my account password.
Any suggestions as to my best course of action, perhaps I should change my account password for a start.
p.s. Each time I log in to the member centre I'm told that I need to update my preferences, I've done that and submitted it 3 or 4 times now but it doesn't appear to have any effect. I wondered if it was just a caching problem on my PC so I tried a refresh and got a sorry we cannot find that page.
longedge
Fixes: 4
Changed my account password and :-
1) Router has updated itself
2) I've sent/recvd email after updating password in Outlook
3) I've logged into member centre
4) Had email confirmation of password change and market research preferences change
BUT with the new password, Cumulus, Filezilla and YAWCAM all fail to log in to ftp.plus.net which resolves to 212.159.8.91. Tracert and ping both timeout to that IP for me. Should I expect to get a response?
subsync
Yes, since yesterday. I'm using filezilla and getting the 530 error on all 4 PN accounts I manage. Sometimes it works, so nothing to do with my settings.
Strat
Fixes: 565
@longedge
I'm getting some errors this morning but I'm expecting it to sort itself out later.
03/05/2019 10:40:00 : FTP Connect Error, Error code = 530
03/05/2019 10:40:30 : FTP Connect Timeout
03/05/2019 10:50:01 : FTP Connect Error, Error code = 530
03/05/2019 10:50:31 : FTP Connect Timeout
03/05/2019 11:00:01 : FTP Connect Error, Error code = 530
03/05/2019 11:00:31 : FTP Connect Timeout
