freenetname support - create a subdomain
- Everything else
- Re: freenetname support - create a subdomain
29-03-2021 12:57 PM - edited 29-03-2021 12:58 PM
I have a domain (registered in my name at nominet) originally created via freenetname, now hosted and supported I believe by Plusnet. Please can anyone advise me whether it is possible to create a subdomain and if so how I go about achieving that?
Thanks,
Paul E.
02-04-2021 12:55 AM
I highly doubt it as the domain interface is very limited. But if it’s possible I suspect you’ll see an option to after you log into your account online here https://secure.madasafish.com/myaccountdx/
02-04-2021 8:53 AM
Thanks for the advice, unfortunately the madasafish account login doesn't recognise one of my user id & password (I'm using the same credentials that I use successfully for ftp, webmail and Outlook forwarding) and when I try the forgotten password route I don't receive the promised email to any of my email accounts.
Paul E.
02-04-2021 9:00 AM
You’d have to login to the Madasafish portal using your full Freenetname email address in the format of username@freenetname.co.uk and the associated password. If you’re trying that with no luck it’s probably worth calling support on 0800 432 0200
02-04-2021 9:12 AM
Again, thanks for the advice, I'll give support a call
Paul E.
- Everything else
