exploit kit on site
- Everything else
- Re: exploit kit on site
exploit kit on site
23-09-2013 7:28 PM
Several months ago my site was infected with an exploit kit so I took it down and reuploaded it. Within a couple of days the kit was back, thinking I might need advice I came on here and it was suggested that a change of password might do the trick. Unfortunately when I changed the password on the home page it did not change for my website uploads,Any ideas.
Message 1 of 5
(1,371 Views)
4 REPLIES 4
23-09-2013 7:38 PM
The upload password is the same as your portal login password and it should have changed automatically - I am not sure why it didn't
Message 2 of 5
(534 Views)
23-09-2013 9:53 PM
I did spend a bit of time trying to upload with the new password. Maybe I had better put in a ticket.
Message 3 of 5
(534 Views)
24-09-2013 9:45 AM
Hi there, just tried refreshing the component, that should sort it out for you - if you give it 20 minutes or so (from time of posting) then try logging in it should have updated.
Message 4 of 5
(534 Views)
26-09-2013 2:40 PM
That's it sorted thank you very much
Message 5 of 5
(534 Views)
- Everything else
