eve killboards
- Everything else
- eve killboards
eve killboards
07-11-2007 1:14 PM
Wasnt sure if this belongs in the games section or here, it is a technical issue so thought this might be right.
I run a EVE.Dev killboard (for EVE online) in my ccgi space. It works great, takes in mails and displays them correctly.
It does have one error though. When you input a mail i'll get an error which mentions the smtp config file in the board. This controls the copying of the mail to a email account of your wish.
The mails are not getting passed on so im guessing the smpt file is not set up right.
Firstly i was wondering if anyone else hosts one of these killboards on plusnet and has some experiance of them and secondly i was wondering if plusnet even have a relay serivce that my killboard can connect to, to pass on these mails from the database.
Thanks for any help
Thanks for any help
Message 1 of 3
(1,867 Views)
2 REPLIES 2
Re: eve killboards
07-11-2007 1:38 PM
relay.plus.net should be sufficient as a relay host for the boards.
B.
B.
Message 2 of 3
(278 Views)
Re: eve killboards
07-11-2007 1:43 PM
ah perfect, thanks a lot
i'll go and modify my config files
thanks
thanks
Message 3 of 3
(278 Views)
