error while uploading coppermine images
- Everything else
- error while uploading coppermine images
13-08-2007 11:54 PM
I keep getting this message from rumpus
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, support@plus.net and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Anyone got any Ideas or similar probs?
Cheers
Cheers
Message 1 of 2
(1,752 Views)
1 REPLY 1
Re: error while uploading coppermine images
14-08-2007 11:05 PM
Where are you uploading the images to - if its into cgi-bin on the ccgi server or a sub-directory of it then you cannot use that folder for normal files, it is designed for shell and perl scripts.
That error can also be caused by a bad or mis-configured script / php file. I would check the configuration and ensure the paths are correct.
Message 2 of 2
(307 Views)
- Everything else
