error message
plantsman
error message
can you please help me with a 'error' problem I have while trying to load my SMF database using MySQL with a php script
After filling in the requred information to 'install' this is the error message Iget
"Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)"
Thank you
3 REPLIES 3
bobpullen
Fixes: 314
Re: error message
Where are you trying to install SMF to? Is it your own box/our CGI servers/the PAYH servers?
plantsman
Re: error message
I have the SMF folders and files uploaded to my  PlusNet CGI space using my ftp program. I'm assuming that the install file would  link up  to MySQL to complete the installation  of the SMF forums, but as mentioned I get the error message.
plantsman
Re: error message
Managed to solve the problem but I'm afraid I couldn't say how - just constant trial an error I suppose. I think I will keep away from things I'm uncertain about.  I'll be sure to make regular backups now.  Thanks.
