editing my website
- Everything else
- editing my website
editing my website
22-12-2007 12:01 PM
When I was with force9, it was a simple matter to go into the website builder wizard to edit my website pages. But now the editing options seem to have disappeared. What am I doing wrong? How can I update my site without having to start from the beginning again?
Thanks for any help.
Message 1 of 5
(2,180 Views)
4 REPLIES 4
Re: editing my website
22-12-2007 2:38 PM
You can download your pages to your PC with FTP.
Make your changes with software of your choice (you can use a text editor).
Upload the page back to your website with FTP.
I recommend the FireFTP plugin on FireFox, but almost any FTP client will work.
There are quite a lot of help pages you can look at on the plusnet portal.
Message 2 of 5
(522 Views)
26-12-2007 7:38 AM
If you are using Internet Explorer v6 you can ftp by going to:
ftp://your_username_go's_here@homepages.force9.net/htdocs/
A box will pop up put your Username & Password in it. you can jrag & drop files to & from your computer.
Hope this helps.
[Edit]
See the Topic: Two websites for more help.
Hope this helps.
[Edit]
Message 3 of 5
(522 Views)
26-12-2007 10:19 AM
After trying IE I changed to Firefox with the FireFTP plugin as it seems to work much better
Message 4 of 5
(522 Views)
28-12-2007 8:42 PM
You might like to consider using NVU - free download from www.nvu.com
It has a website management tool that lets you edit existing sites.
Message 5 of 5
(522 Views)
