eMetrics/Statistics causing Javascript error on my sites
Vega
Hi
eMetrics is causing the following error on my ccgi wesites - 'Uncaught ReferenceError: wiredminds is not defined'
I also notice that my statistics are not working anyway and come up with the following error (see screenshot). Can my analytics/statistics be disabled?
Regards
2 REPLIES 2
spraxyt
Aspiring Legend
Fixes: 75
Re: eMetrics/Statistics causing Javascript error on my sites
You should be able to turn off the wiredminds pixel code to disable analytics by logging into the control panel. Then open the Web Analytics tool, and once the tool opens go to the Advanced tab. Choose Manage Pixel Code in the menu, then the Disable radio button and OK.
That should stop the WiredMinds Javascript code being added to pages, effectively turning Analytics off.
David
David
Vega
Many thanks spraxyt, all done. Will try some tests on the site load times now
