dyndns.org help please
- Everything else
- dyndns.org help please
08-07-2015 8:40 PM
Thanks a lot
(wasn't sure exactly where to add my post to, please move if needed)
Re: dyndns.org help please
08-07-2015 9:11 PM
Then - problem solved!
York.
08-07-2015 10:11 PM
08-07-2015 10:14 PM
York.
09-07-2015 11:08 AM
If you've now got a static IP then you shouldn't need to use a dynamic DNS hostname.
Instead of browsing to hostname.dyndns.org when trying to access your webcams, just use the IP address, e.g. http(s)://212.159.X.X
If for some reason you still want to use a dynamic DNS service, then it might be worth trying an alterrnative like dtdns.com if your router/client supports it.
09-07-2015 7:44 PM
I know my supplied ISP static IP can't change, and it hasn't, but as far as dyn's site software is concerned, when it updates itself it's changing any IP that I enter to a random IP address starting with 146.xx which are American IP's. This kills my cam and happens a few days later. This has only happened in the last few months on plusnets network.
Am I making better sense? I am getting old
09-07-2015 8:17 PM
09-07-2015 8:29 PM
Quote from: launton when it updates itself it's changing any IP that I enter to a random IP address starting with 146.xx which are American IP's.
What is causing the IP address to update? Do you have something on your network that is ruuning a DynDNS update client? The address shouldn't be changing at all unless you're telling it to... It looks to me that your update client hasn't correctly updated the discovered WAN address.
Take a look at your camera settings and see if it has a built in DynDNS updater - If so, try rebooting the camera and see if that fixes it? Is it your router that runs the update? If so, give that a kick instead!
Another thought - Have you sold/passed on a previously used router or other device that may be updating the setting? If all else fails, change your DynDNS password and the problem should go away
09-07-2015 8:40 PM
Dyndns then amends the IP address for the url for your site out on the web.
I hope that you're not paying Dyndns and using a static IP address!
York.
09-07-2015 8:40 PM
I guess the answer is I don't know. The router is an Asus RT-AC68U with Merlin firmware. I guess that could be pumping out something under using my dyn account causing it to happen.
09-07-2015 8:44 PM
York.
09-07-2015 8:44 PM
Quote from: NedLudd You don't need Dyndns with a static address. All Dyndns does is receive IP address changes by locating some updating software on your PC!
It then amends the IP address for the url out on the web.
I use dyn for other things too like monitoring the works cameras at home.
I know how it works and what it does.
09-07-2015 8:48 PM
York.
09-07-2015 8:49 PM
Quote from: NedLudd But, if that's what happening then you can't be using a static IP address. If you are, then the auto IP address update will not happen as your IP address has not changed!
Well somethings changing it, or we wouldn't be having this conversation
09-07-2015 8:50 PM
Quote from: NedLudd You can monitor the cameras at home by using your static IP address - http://www.111.222.333.444:port number for camera!
I know I can, but that's not why I'm asking the question.
- Everything else
