domain on a sub folder
- Everything else
- domain on a sub folder
19-01-2012 3:32 PM
So here's what I'm looking to do.
I want to set up a domain, let's call it example.co.uk, and have it applied to mywebspace.plus.com/folder, rather than the main webspace.plus.com. I don't know if this is possible, or if it is, whether I can do this to other subfolders too. I'm quite happy just to use the rest of mywebspace.plus.com as I have been without adding any further domains.
Does this make sense? Can I set it up this way? How would I go about setting it up?
Message 1 of 4
(1,191 Views)
3 REPLIES 3
Re: domain on a sub folder
19-01-2012 3:54 PM
Hi esseff,
If you go into your account and select Domain Names in the left hand menu, you can select configure under the domain in question then type the folder name in that you want it to point to. You'll have to have the domain registered with us to do this.
Jojo
Jojo
Message 2 of 4
(297 Views)
19-01-2012 9:05 PM
Hi Joanne
Thanks for that.
As I already have a domain name I'd like to use for this, can't I just transfer it in and choose the folder? What's the difference between transferring and registering?
Thanks for that.
Message 3 of 4
(297 Views)
19-01-2012 11:14 PM
As far as I'm aware the domain needs to be hosted at Plusnet but needn't be registered there. The 2-step transfer process is explained in the Hosting Only section of the Hosting guide.
David
David
David
Message 4 of 4
(297 Views)
- Everything else
