domain name in address bar
- Everything else
- Re: domain name in address bar
17-02-2011 6:09 PM
Hi
I have set up my web hosting package with streamline.net and my domain names are registered with 1&1
When I type my domain name into the browser the 1&1 automatically forward it to my streamline account as I want it to.
The only thing I am not happy with is that the address in the address bar no longer displays my domain name.
I don't really want my domain names registered with streamline so I'm wondering if there are any tricks to make my .co.uk name to remain in the browser address bar instead of streamlines gobbledegook
I'd be grateful for any help
Message 1 of 9
(2,018 Views)
8 REPLIES 8
17-02-2011 8:14 PM
You will be best to use framed web-forwarding, if you do not want streamline to have anything to do with your Domain Name.
Message 2 of 9
(722 Views)
17-02-2011 10:14 PM
Quote from: Midnight You will be best to use framed web-forwarding, if you do not want streamline to have anything to do with your Domain Name.
Thanks a lot for that. I changed the settings and it's workes almost straight away
Do you know if that setup effects search engine optimization?
When I reset it to framed in 1&1 I was able to add title, description and keywords.
I guess that must be equivalent to Meta tags
Message 3 of 9
(722 Views)
17-02-2011 10:54 PM
Yes, it will affect search engines as they don't like being redirected too often (if at all on some).
Message 4 of 9
(722 Views)
18-02-2011 7:34 PM
Best bet is actually to change nameservers or setup an A record instead for the DNS.
Message 5 of 9
(722 Views)
18-02-2011 7:39 PM
@okrzynska, He does not want streamline to have anything to do with his Domain Name, so change nameservers is out.
Message 6 of 9
(722 Views)
19-02-2011 8:42 PM
Yes but how do you define having anything to do with? - Nameservers or registration?
Personally I say an A record is best and that avoids a name server change.
Message 7 of 9
(722 Views)
20-02-2011 4:31 AM
Thanks, but could you explain what an A record is? what does it mean?
dick:quote
dick:quote
Message 8 of 9
(722 Views)
20-02-2011 11:11 AM
Some info here http://www.plus.net/support/hosting/domains/domain_admin_dns.shtml
Message 9 of 9
(722 Views)
- Everything else
