domain hosting
- Everything else
- Re: unlimited?
domain hosting
18-09-2013 2:13 PM
Best regards, Mick
Re: unlimited?
18-09-2013 2:17 PM
domain hosting
18-09-2013 2:17 PM
I found this answer on the FAQ:
Plusnet Unlimited/Essentials FAQ - December 2012
I’m using ‘extras’ that aren’t offered any more e.g. webspace, fax-2-email, hosted domains. If I request an account change will I keep these extras?
Yes, any legacy product features will be carried across to the new account type.
Is there anyone in plusnet who can tell me the exact official position, as I am going round in circles with support staff.
Re: domain hosting
18-09-2013 2:20 PM
Topics merged as they are asking the same question.
Re: domain hosting
18-09-2013 2:26 PM
Re: domain hosting
18-09-2013 3:56 PM
@Mick Assuming the above comment is not an issue I can't see any reason for not upgrading to Unlimited. I changed from PAYG to Extra then Unlimited, webspace, hosting and static IP retained. Fax-2-Email I didn't use and allowed to lapse.
David
Re: domain hosting
18-09-2013 4:16 PM
I did take the precaution before each upgrade, to ensure that every feature was being actively used and was working.
I see no reason why you should have any trouble, although you might want to take a backup of your webspace just in case !
Re: domain hosting
18-09-2013 4:43 PM
Re: domain hosting
18-09-2013 6:16 PM
I have tried adding the new domains first as suggested here and by pn support, but it did not work. When I raised a ticket I was then told that it was no longer possible despite being assured in writing that I would retain this option before my last product change. I would certainly have transferred in these domains before moving to another product.
Perhaps pn support should get a bit of training on this legacy issue for old accounts so that they are all singing from the same hymn sheet.
regards
Re: domain hosting
18-09-2013 6:21 PM
Quote from: spraxyt The only qualification one needs to be aware of is that I believe the rule is that legacy features actually in use are retained, but those not in use might be lost.
So you could keep your existing domains but not add new.
Re: domain hosting
20-09-2013 2:09 PM
Best regards, Mick.
Re: domain hosting
09-10-2013 9:47 PM
if you're installing open source software remember that not all features will be
compatible with PN Legacy platforms
Re: domain hosting
27-10-2013 11:27 PM
Fixed IP cannot be retained across a package update to 'essentials' (unless someone from PN would like to contradict this for me ).
