dns "@" A-record for domain root [SOLVED]
- Everything else
- dns "@" A-record for domain root [SOLVED]
18-05-2015 3:08 PM
How do you enter an A record for the top of a domain on the Plusnet DNS tool?
Say I want to point "example.com" at 1.2.3.4, How do I do it?
I thought the convention was "@" for this but it isn't accepted by the tool. I've entered "." for it; is that right?
If not, what's the right way.
Thanks.
left @
type A
right 1.2.3.4
Thanks.
Message 1 of 4
(1,491 Views)
3 REPLIES 3
Re: dns "@" A-record for domain root
18-05-2015 4:05 PM
Sorry, don't know what "." alone will give. However you could try entering example.com. in the left field (full stop after the domain name).
David
Message 2 of 4
(662 Views)
18-05-2015 5:32 PM
A '.' won't work.
I think you can leave it blank. To be on the safe side though, enter yourdomain.tld. (with the qualifying dot at the end) like spraxyt's suggested.
Message 3 of 4
(662 Views)
19-05-2015 8:35 AM
Thanks. Whilst waiting for the definitive answer I tried "example.com." (note the trailing dot) and waited for it to propagate. and that appears to have worked.
Message 4 of 4
(662 Views)
- Everything else
