cgi space and webspace confusion
- Everything else
- cgi space and webspace confusion
22-10-2007 9:46 PM
i hope that makes sense.
Re: cgi space and webspace confusion
22-10-2007 9:52 PM
22-10-2007 11:25 PM
one other thing...how much space is on there? is ur webspace amount across both areas?
23-10-2007 12:18 AM
In practice the ccgi webspace is not really checked like your www webspace but your site could be archived if you exceed your allowance on either www or ccgi.
06-11-2007 1:03 AM
06-11-2007 1:30 AM
FP is something with FrontPage extensions, a propietary program to design webpages - generates awful code.
06-11-2007 2:48 AM
06-11-2007 1:43 PM
07-11-2007 12:30 AM
Internal Server Error so dont know where i am going wrong. I also tried to get into the setup as it sugested and it just keeps taking me back to the input page Regs Andy
08-11-2007 12:13 AM
On my ccgi space are no problems. I downloaded the guestbook from the webpage, unzipped it, created in cgi-bin on my ccgi-space the folder guestbook, uploaded the single file guestbook.cgi with FileZilla in the transfer type Auto - they say to use ASCII mode - , chmod to 755 the directory guestbook and the file guestbook.cgi. I then browsed to the file and everything works (I am on PlusNet, so it is http://ccgi.username.plus.com/cgi-bin/guestbook/guestbook.cgi ).
Just try it again from scratch.
Hope this helps
08-11-2007 11:00 AM
I had many a problems myself and kinda found my way out of them ok. 9 times out of 10 it was down to permissions, most php files wants to me chmod at 755.
If your stuck, drop me an email at adam.venn @ bridgesltd.co.uk i'd be happy to help.
Its quite annoying how you have to send people to a different address from your original website.
16-11-2007 11:48 PM
I can update to the www part without any problem, but cannot work out how to get the ccgi settings loaded correctly.
I've looked at my home settings using Putty and tried copying them in, but I'm not sure if this is correct.
17-11-2007 6:56 PM
Looking at this, can I just point the website at the testing server to run php files etc placed there?
20-11-2007 12:31 PM
I have a feedback form hosted on my www. site which executes the .php file hosting on my ccgi section.
Within the cgi file is a line to point the user back to www.mydomain.com/thankyou.html after the php file has been executed.
If you need any help, drop me an email barteh@gmail.com
- Everything else
